I am trying to figure out how to run a remote PS pump/reservoir on my 73 Cuda (416 CI, EFI 6 pac) and wondering if anyone out there is or has done it. There appears to be several options running from the Type II GM style to the late model Mopar versions. However I do not know the line pressure I should be looking for and subsequently would will work. I want to run one to clean up the left side of the motor and since this is a bit of a road race car, I think it will give me some options; not to mention I am not fond of the factory PS pumps, expecially thier pulleys. I can fabricate the brackets once I have a pumpt to work with.
