I always just used a piece of wood and a hammer and tapped it in going around the diameter to make sure it goes in even.
X2 & just pack the back recess of both of em full of vaseline to keep the spring in place as it's driven in and the vaseline melts out and is compatible with and causes no probs with the tranny fluid
