I am going to be replacing the front pump seal on my 67 Dodge and meant to grab the seal before I left for work. I need to make a seal installer to install it with out removing the pump.
If somebody could measure the inner and outer dia of the seal and also how long the input shaft is would be a great help. While your at it could you measure the output shaft seal too, might as well do that one too. I'm off for the next 9 days and don't want to have to buy anything for the job.
Thank you, Jeff
