Alot of the comp guys used to convert them to run the thrust bearing, but it did require machining the block.
I made up a few tall deck plates for those belt drives, although I had a seniors moment and put the idler bolt holes in the wrong position. They are collecting dust in a cuboard at work nowadays. I might get around to making the plugs and repositioning them.
Alan Jones
