Pulley size will depend upon how much boost you actually want or have fuel for. Maxing out the blower's shaft speed will max out boost production, but will everything else handle it?
What method will you use for additional fuel to keep up with boost?
In tank Walbro 255 lph pump. Plus bigger injectors obviously.
If that doesn't support enough fuel, then I'l try a denso in tank 380 lph pump.
I won't order injectors until I decide if I'm going with MS or SCT. Both would be tuned on the dyno. Probably going to be 60# injectors, but I'll wait and see if I need high Z or low Z.
