In process of replacing me dash pad. I figured this would be a good time to get the Dome light functioning.
1. Where does the Yellow & pink wires route/connect to.
2. What color coded wires should be connected to the left and right two terminal door switches.
Without help I will most likely end up taking apart the whole car.
Also, for the most part my repair manual is good, however it's the size of an aircraft manual and some information is marginal.
Would appreciate your help
