With 255 they shouldn't rub leafs, the rear is narrower than it should be if it were stock, he should have checked clearance there before driving car because you only need 1/4 inch clearance there, is he Shure its not rubbing the inner wheelwell? Even if you have more than 1/2 inch clearance with worn springs or bushings it will rub there.
