Not really... should be in the 525-550 hp range... pump gas, 10.53 compression, W-5 heads w/2.08 intake valves, ported w/310 cfm at .650, cam is a 260/262 640/640 with a 105 LSA in at 105, TD rockers, M1 intake... right now it has a 850 on top but I do have a 1050... I only want the Rampage to run 10.1 - 10.2 ... this is my street rod/drag week car.... this engine is pretty much built from parts I had laying around the shop other than the pistons
