I dont know much about automatic trans but on mine the lever that applies the band for reverse broke
Low/Reverse band, strut, or servo failure.
If this was the case it shouldn't pull the engine down liked it's locked up. It would just act like high gear. He also never said if it drives in neutral.
It doesn't drive in neutral.
