No stating of what brand (unless I missed it) & it certainly be less quality than the aforementioned $500 kits but I'd think you'd be fine w it
At least it has a lifetime warranty , Moog is outsourcing to asia now so quality won't be much better . I put a set of Moog LCA bushing in my Dart and they were surfce cracked in 4 months of very limited use , installed in September , raced it once, drove maybe 300 miles, then the car sat in my garage all winter ...
Did you go with rubber or urethane?
I priced it out and the list follows. Im looking at about $320 with all Moog stuff. If I nix the factory idler arm from the list and pick up the fast ratio pitman and idler arm from Firm Feel I'd be looking at about $570.
*Ball Joint -Upper $14.81 ea -Lower $37.99 ea *Control Arm Bushings -Upper $22.79/ kit -Lower $9.91 ea *Strut Rod Bushings $13.52 kit *Tie Rod adj sleeve $14 ea *Tie Rod Ends 9/16" -Inner $13 -Outer $12 *Bumpstops -Upper $5.27 ea -Lower $5.88 ea *Idler $35.79 *Stabilizer bar link & bushings $12 *Stabilizer bar (to k frame) bushings $6 pr
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
