its not the bezel, its the position of the zinc bracket that the cable is attached to underneath. the only way to do this properly is to thread the antenna in and use it to turn the bracket under the panel and with your other hand gently try to push the part of the bezel that sticks out into the notch of the bracket underneath. its takes a few times before you get the right position. or take the cable assembly out altogether and test fit everything on the bench so you know where the notch on the bracket should be positioned so the bezel will sit correctly. good luck
