Quote: Russ..my deck heights avg. 10.715"..gasket thickness compressed is .039..the pistons are Diamond flat tops,and the chamber volume is 84cc. Have an idea on the MAX comp. ratio?
Randy the cam has a BIG play with what the real(dynamic) compression is... when the intake closes
