What sort of heads + intake would work good with a 'big' 273? If the engine can turn 7k+ you would need heads that flow at that rpm. Would a set of ported magnum heads work? I assume a 2.02 valve head doesn't fit on a 273 block?
A set of old school iron W2's would be a fun experiment if they fit.
