Did your rocker panels have rivets sticking out that the plastic clips mount to, then you snap the rocker molding over the plastic clips . . . or did you replace the rocker panels and no longer have these studs ?? If that is the case, then you have to drill holes in the rockers and install rivets for the plastic clips, or screw the clips on . . . .
Hope that helps . . .
Cheers
Mark
