i agree with Andy and have always used the back of the block in a stock block application. Best pass to the mains.
the extra port remote filter because any oil discharged from the sump in a low pressure situation would be following the path exactly like camme from the pump.Then on the filter port I would be using #12 AN rather than #4 .
SIZE DOES MATTER
home of the
Sox and Martin Hemi Duster
