UPDATE*****the lower LCA bushing are not bad, the rubber i thought i saw was actually grass and mud from the ditch, i raised the left side torsion bar and every thing is even at 27inches, not rubbing, had a local front end shop look at the front end, they said front end look okay, everything is tight, so i dodged a bullet on this one, the frontend guy did suggest the larger bars, he sd the car wld handle better with the larger bars due to the big block>
