Kind of figured they just missed it by a tooth when they marked it,just trying to warn people.
I never run them with just lining up the dots,but you have to start somewhere.
Keith
I dont even have dots... I set the intake lifter on
the max lift then set the crank to the degree its
suppose to be then slide my gears on then check again
