When I first built mine 340 the cam key way was off
27*... I did the dot to dot to get a base line and
couldnt understand why the valve was hitting the piston...
the cam worked fine once I degreed it but forget that
dot to dot stuff... like you said I dont know how some
guys do the dot to dot and call it good
