Tirerack.com lists a Firehawk and a BFG in 255/60-15. It's a 27" tire so make sure it will fit when you turn.
It's pretty close in size to the 245/45-18 I run on the hot rod. That is definately the largest tire that will fit under an early B.
Feets, I have thought about a 255-60-15 as well and will see if I can get one mounted up and see how it fits. I would like my front tires a bit taller but still have a wide profile. And yes 235-245 60 front tires are not wide! Interesting that Rick E was running a 285-50-15 on the front of his bird, it would definitly be a tight fit. I can jam a 275-50-15 under there as Nitto makes that size but not sure how their drag radial type tire will react on the front of the car. I would guess they would work with all the front wheel drive cars out there nowadays.
