Quote: I would think your case,spool & axles should be fine unless it was injured. You may have broke the sprag in your transmission,You may want to pull the trans & check.
I called my tranny guy and he said if the overrunning clutch was gone that I would have no first gear and I did manage to back it up and put it up on the trailer in forword in low gear.
Is the guy going to stand behind that statement if and when your front drum comes thru the floor of your car ?
