Thanks. It has a stock 2000 360 magnum with a .501/.513 hyd roller, 9:1 comp and a Holley 950. Stock untouched magnum heads and also 1 1/2" block huggers with 3" Flowmasters.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
