Old best was 7.46 @ 91 with 1.54 60 in Oct. of last year with old 9 1/2in PTC converter. Upgraded to 8in PTC converter and ran a best of 7.32 @ 92 with 1.53 60 last night @ T&T. I was thinking that it would pick up mostly in 60ft but it picked up mostly on the top end. It also had a bad high RPM miss shifting @ 5800 so I started shifting @ 5600 and that is when it ran the 7.32. It's a 360/380HP crate motor at 3000 lbs.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
