scotchbrite disc with the mini air angle grinder
i also like to use a stright wire brush thats about 1" round and very stiff in the mini grinder.
I use the brush to de-carbon the combustion chambers and valves before R&R them as well.
when the scotchbrite wont cut it then its to the wire brush or wire wheel.
use air to blow cyls clean or a shop vac them out.
they do make a spray gasket remover also,you can find it at napa for a few bux.
good luck and ez on the loony-um
