I run a stock mini starter from a 92 DAK 5.2 engine on my 440
if you go newer yr watch for the plug change,97 or so IIRC
some have a extention piece you remove to use the studs right off the starter.
my last 2 have been U-pull it speicals for 14$
I just use the stock Chrysler mini starter... been
in there for years.... I'll use the same thing on
my new engine
