Re: Density alt, vapor press, or water grains????????
[Re: MR_P_BODY]
#1060220
08/24/11 10:40 AM
08/24/11 10:40 AM
Posts: 3,453 Dandridge TN
Dabee
Dandridge TN
It doesnt matter if its off by 120ft just as long as its always off 120ft.... you use that one unit on your car ONLY..... Bill I cant say weather the VP is better or not... I've always used the DA on my unit(its about 10 years old now) but I've always been VERY HAPPY with it and its predictions to what the car will run... mine is within a few thousandths, which is closer than you need to dial... if it says I should run a 9.009 I put .01 on the window but if its a .005 I go with .00... its that close and the car is also
My ten year old TAG consistently has predicted ET’s with in .003. I have run gas, alky and E-85, in three different cars and it made no difference. All I did was dump the data and start with a fresh data base when switching fuel and or cars. The key is you need a few good runs in the data base to accurately predict. Also like Cab said if you make any changes to the car dump the data and start over.
Entire Thread
WILD BILL
08/23/11 05:18 PM
Cab_Burge
08/23/11 07:18 PM
440Jim
08/23/11 07:19 PM
WILD BILL
08/23/11 07:38 PM
MR_P_BODY
08/23/11 08:13 PM
WILD BILL
08/24/11 12:12 AM
Butch
08/24/11 01:04 AM
Barnstorm
08/24/11 01:13 AM
WILD BILL
08/24/11 01:25 AM
MR_P_BODY
08/24/11 01:40 AM
VernMotor
08/24/11 01:47 AM
Barnstorm
08/24/11 02:55 AM
MR_P_BODY
08/24/11 03:12 AM
Dabee
08/24/11 02:40 PM
WILD BILL
08/24/11 02:56 PM
CompWedgeEngines
08/24/11 04:10 PM
WILD BILL
08/24/11 04:30 PM
Dunnuck Racing
08/24/11 04:37 PM
pittsburghracer
08/24/11 04:47 PM
VernMotor
08/25/11 01:31 AM
CHAPPER
08/24/11 01:50 AM
Cab_Burge
08/24/11 02:15 AM
WILD BILL
08/24/11 02:28 AM
