Buy the Kestrel for the water grains and wind information, use the TAG for predicting with its information based on RH You will see the trend on the ET differences between the little cars on alcohol versus the big car on gas.Do you keep two different data input logs for the big car versus the JRs? If not, why not, for predicting
