Quote: As I have said in the past if you cannot make 800hp with a decent set of B1's your doing it wrong. My 67 Valaint was a basic 511 low deck with a good set of B1's that went 9.0's at 150 weiging 3470lbs. My current MC motor seems to run ok
i would say you are right there, my 499 -1 setup figures out to about 750hp 5.0x at 1854lbs
