I just lost my trans reverse in my baracuda, i rebuilt it myself and had issues with the front pump seal 2x's. I could just pull it and try to fix it again OR i have a A body 18 spline 4 speed sitting in my garage begging to be used. I have a 8 bolt crank in my motor and no clutch or flywheel. I have a lakewood bellhousing, so im good there, and will be putting in my fenderwell headers so linkage shouod not be an issue, thinking of converting to hydro from a ram.
my question is does anyonje know where i could get a decent 18 spline clutch for under 300. I cant seem to find much more than twin disc setups for over 1000. I cannot afford that.
its a stroker 440 8 bolt like i said- if you have a flywheel or clutch you would like to sell let me know! Or if you just have info on where to buy it i would greatly apprecite it.
