Arc,
Does your car weigh 2400#'s with the driver and full of fuel? That's some motor. Also, what block? 5 cam bearing or 9? Size CI would be good to know and if it's a water block or not. Thanks and nice build with killer numbers.
2300 after a pass with driver.I have a cn billet block with a 60 mm 9 cam bearings it is a water block.the dyno is the same one your motor was on last week.
