Is that the trans or the clutch? I don't know anything about your setup but some of the guys I've talked to run the McLeod adjustable clutch. It takes a little work under the car to adjust it for street driving but it can be done. Of course, it isn't something that I'd do either! I tried to run that setup for a while and I got tired of messing with it. I just went back to a simple setup that was slower, but didn't require so much babysitting.
