I have used 2295 a long time ago. THEY ARE VER HEAVY. and the pin is heavy
turning 6500 with those iis like turning 7500n with a lighter piston.
eventually .. one of those rods will break.
SO I would recommend an NEW aftermarket rod. they will be brand new , good materials, good bolts and bushed pins and MUCH stronger than stock. For a small expense now, or actually the same once you get done working on the rods you have, you will have something that will last.
agree with this..they was a set of aftermarket rods I had re bushed..long story
