I am about to install a 727 and 440 in my 69 B body. what is the easiest whay to do it. I will not be able to bring it from the bottom on the K member.
Do i drop in the engine from the top then bolt up the tranny from under the car, or do i put the engine and tranny together outside the car and drop them as a unit from the top.
