Seems like brian at imm engines (ou812)has an article coming out about them? Or maybe its super stealths I can't remember.
Yeah, but we're starting with a 400, with budget in mind. The second article will be a stroker BB and ported MW Victors.
Once you get past the pushrod clearancing they are a great cylinder head.
If the guys at Koleno play along there will be a 3rd article based on their lowdeck block, and MAX effort Victor heads using either a vac pump or maybe dry sump. We want to see the very best they have to offer in a single 4 barrel build.
Brian
Brian Hafliger
