If you have an automatic, one problem will be idle speed after you put it in gear. Vacuum will drop, once put in drive, and idle speed will then be to low. Also, I found out that when you mash the power brake hard at idle, that also uses more vacuume which in turn takes away advance, which may stall the engine, then no power brakes.
