thats the thing mrp there is no damage to the rim any where that i can see... its just a hair line crack that took me a while to find ....i had tires put on this thing about 8mths ago and no problems til now ... i put it in the shop and came out the next day tire was low and thought i had ran over a nail or something ...spray the tire with soap and water nothing so i just sprayed the whole thing thinking its in the side wall...you really cant see the crack i only know where its at now cause i marked the tire.....the rim is about .5 thick where its cracked at and right and the bottom of the flat that the tire seals on...now this is a heavy duty rim that carry alot of weight..i want to say 16/18000 lb axle... :
I dont know how old it is BUT I might call the manufacturer
and see if they will replace it... since it shows
NO SIGN of damage... they dont want a bad rap out
there about their wheels... also being that its
carrying that kind of load... no way would I have
it welded
