Out of curiosity, what are you using for a floor hump? I would like to see some pics of the hump installed, too. :
The pedals and hump I have are out of a '77 Volare. At least that's what the seller told me. I don't have the hump secured to the floor yet, but it seems to fit perfectly. I'm not sure if I'm going to weld it or just use screws.
I figured the Volare pedals and bracket would be a bolt in, but when I tried it in the car the the "ears" on the end that bolt up to the column support bracket were about an inch too short. I had to swap the pedals and spring bracket over to the Mirada piece but it all fit fine.
The hole for the clutch pushrod is already in the firewall too, it just has a grommet in it.
