If the battery is fully charged to maximum capacity you will not see this. But, that rarely is the case. So yes the drop is normal. Your battery is a resister and the wire feeding from the alternator has some resistance too. The larger the wire you run and the better the contacts are the less drop. But, you will always have something if the alternator is indeed charging.
Leon
Thanks Leon
I run a 6 gauge from the alt. to the master power switch and 1/0 welding wire from the battery to the switch to the for solenoid under the dash. I just want to make sure I am getting everything I am supposed to from the alt. to the battery.
Thank you
