had similar situation .1 of the mixture screw washers/seals,cork type,had shrunk.screw backed out .
must of sucked there.replaced the mixture screw seal,reset mixture - whistle gone
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
