Last night I also disconnected both the blue and green wires on the alterator. From one of the post on the alternator I took it with a seperate wire to ground on battery on the other post i used another seperate wire and went to the postive post. With the car ideling, I still only had 12V across the positive and negative post on the battery.
'69 Barracuda 340 4-speed
'73 Cuda PROJECT
