I am having a no charge issue with my 73 Cuda and have a question about testing the alternator. To "full field" the alternator, I just unplug both field wires from the alternator and with two seperate wires take one alternator field post to the Negative side of battery and one to the positive side? Is this right? If the alternator is good then I should have 14+ volts at idle right?
'69 Barracuda 340 4-speed
'73 Cuda PROJECT
