id really like to pull off 6-700hp
600 or 700, 100hp is a big difference?
Either way at that level you are starting to get to the max hp level the block is capable of handling long term 600 not so much as 700, you'll need to go to studs on the bottom end and possibly a girdle if space permits ...
What's your budget ?
