I'm doing a 318 => 383 swap on my Satellite. The original 22" radiator worked great on the 318. Can I re-use this radiator with the bigger, yet very mild, 383?
Sorry guys, but if it is a 66-69 radiator the upper connection is in the same place. The lower is a little too far inboard and needs to be moved out to the and of the tank. It is also a 1 1/2" connection which needs to be made into a 1 3/4" conncetion at the time of the move. It my or may not cool though. Should go to a 3-row core when the swapping is done but it's your cash. Call me if you have any other questions.
Good luck,
Bob Schirmer
Glen-ray Radiators
1.800.537.3775
