How the heck is THAT possible?
And I thought most of you guys were as old as I am....obviously not. Here's how it's done and trust me I done it a bizillion times.
Remove the rocker and push rods assembly from the heads. Take a telescoping round magnet down thru the push rod holes in the head and pick up the old lifter, pulling it up thru the same area, obviously. You install the new lifter the same way. Works every time providing you aren't using alum. heads with small push rod holes.
