We used a lite on it to set it. Ronnie
what did you set it at?
did you use a vac gauge to set the idle air screws on the carb?
let off gas or give it gas and it stops
sure its not an exhast leak?
retard timeing will kill off the power
advance time will add power till you go to far,then it will rattle and not have power
