Dodgem,
I did check the Harmonic Balancer for correctness when the motor was rebuilt and the timing marks are pretty much on except for whatever slop there is in the timing chain.
Now the timing light may be a different matter, but I did check it against a non-dial back timing light that I have and they both show approximately (within about 2 degrees) the same results.
