Quote: DO THE SHAFTS HAVE A HOLE IN THEM TO OIL THE ROCKER? MAKE SURE THAT HOLE IS POINTING DOWN NOT UP....UP WOULD GIVE LITTLE OR NO OIL THROUGH THE ROCKER. ALSO MAKE SURE THE HOLES DRILLED IN THE ROCKERS TO OIL THE SPRING AND PUSHROD CUP ARE DRILLED ALL THE WAY THROUGH
Bigger holes point down, smaller chamfered holes face the adjuster. I triple checked that when I put it back together. I also put moly paste on everything to help with the dry start
