Roller cam first timer I'd prefer part numbers for stuff you
#3289137
02/13/25 10:36 AM
02/13/25 10:36 AM
Posts: 1,530 Martinsville, IN
cdwmotorsports
Martinsville, IN
Refresher, last year I messed up and hurt my 451. Long story short I didn't read a footnote for a 25 year old set of pistons when putting on new heads. Engine shop called yesterday and the short block is done.
With all of that being said, I'm not going back to a hydraulic flat tappet cam. I want a roller and I want it to last. So my question is who and what.
Who's cam to use and what size is appropriate? Was a .509 Mopar cam
What all parts do I need aside from the cam and lifters. My best guess is, timing cover, cam button, pushrods
I have a set of Manton pushrods I presume won't work with the new cam/lifter combo. I'm ok with seeing if they'll fix them for the new cam.
451, 10.1 is what I was told compression will be with the new pistons and heads which is about where it was prior to my screwing up. 727, TC is currently a Turbo Action 3000 stall (TC set to be upgraded, I'd take suggestions on that too) 8.75 3.91/spool
I drive it on the street and will be doing Dragweek in it this year instead of the Duster I had to use last year due to my mistake. Anything I forgot let me know and I'll include what I know.
eBay-cdwmotorsports
Re: Roller cam first timer
[Re: DGS]
#3289161
02/13/25 11:48 AM
02/13/25 11:48 AM
cdwmotorsports
Martinsville, IN
Don't forget new valve springs (+retainers) and oil pump drive! What specifically changes for the springs? I presume the oil pump drive goes to bronze?
eBay-cdwmotorsports
[Re: cdwmotorsports]
#3289171
02/13/25 12:08 PM
02/13/25 12:08 PM
Posts: 13,657 Marion, South Carolina [><]
an8sec70cuda
Will need more spring pressure for the more aggressive roller lobes. Either bronze or a melonized dist. gear. Just call Dwayne Porter (fast68plymouth) for a cam. The dude is awesome at spec'ing cams. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
[Re: an8sec70cuda]
#3289197
02/13/25 01:36 PM
02/13/25 01:36 PM
Posts: 1,039 ohio
67mprfan
ohio
If using stock timing cover, most reinforce it to prevent cam walk
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: birdtracker]
#3289434
02/14/25 02:42 PM
02/14/25 02:42 PM
Posts: 4,336 Puyallup, WA
LemonWedge
Puyallup, WA
remember what they say about opinions. Here is mine. The performance level you are at is no were even close to need a roller cam. Especially for drag and drive events. A stock hydraulic cam would be more reliable and build just as much power. 2 cam choices from my previous builds. Crane made a .528 hydraulic and also the 440 police interceptor camshaft used by State Patrol cars would be a good choice. Birdtracker My opinion differs. We’ve reached a time where I believe roller stuff is now more reliable than flat-tappet designs. Due in large part to materials available to the aftermarket cam manufacturers, or at least the constraints in materials availability that is put on them by cost-driven factors. The fact that every OEM engine in production today utilizes a hydraulic roller valvetrain is evidence of the reliability of the technology. Also, there’s no way you’re going to convince me that a flat tappet at the same overall duration would make just as much power as a roller design. A simple look at a graph showing area under the curve would suggest especially with a moderate cam, you’re getting a LOT more flow capability with a hydraulic roller than a HFT cam. The relatively large dia. Mopar lifter negates this to some extent, IF the flat tappet is a Mopar specific grind. But the realities of the math are still there. With that said, I agree that it’s largely a “no bad choices” situation. There will be pros & cons to whatever is chosen. A flat tappet can perform at the level the OP seems to be targeting, with cost as the main benefit.
LemonWedge - Street heavy / Strip ready. 468” Lowdeck MaxWedge - 10.42 @ 128
[Re: LemonWedge]
#3289478
02/14/25 05:08 PM
02/14/25 05:08 PM
Posts: 750 Southern Alberta
Uberpube
Southern Alberta
remember what they say about opinions. Here is mine. The performance level you are at is no were even close to need a roller cam. Especially for drag and drive events. A stock hydraulic cam would be more reliable and build just as much power. 2 cam choices from my previous builds. Crane made a .528 hydraulic and also the 440 police interceptor camshaft used by State Patrol cars would be a good choice. Birdtracker My opinion differs. We’ve reached a time where I believe roller stuff is now more reliable than flat-tappet designs. Due in large part to materials available to the aftermarket cam manufacturers, or at least the constraints in materials availability that is put on them by cost-driven factors. The fact that every OEM engine in production today utilizes a hydraulic roller valvetrain is evidence of the reliability of the technology. Also, there’s no way you’re going to convince me that a flat tappet at the same overall duration would make just as much power as a roller design. A simple look at a graph showing area under the curve would suggest especially with a moderate cam, you’re getting a LOT more flow capability with a hydraulic roller than a HFT cam. The relatively large dia. Mopar lifter negates this to some extent, IF the flat tappet is a Mopar specific grind. But the realities of the math are still there. With that said, I agree that it’s largely a “no bad choices” situation. There will be pros & cons to whatever is chosen. A flat tappet can perform at the level the OP seems to be targeting, with cost as the main benefit. Cummins's roller setup is a dud....The fix for their mess is to go back to solid flat tappets which last forever in that engine. You can use a stock timing cover as is, just put a gob of silicone between the cover and the back of the water pump, works fine. Don't forget a bronze tipped fuel pump rod if you are are running mechanical fuel pump.
