Re: SAME CAM SPEC FLAT TAPPET /ROLLER
[Re: A/MP]
#3289149
02/13/25 11:24 AM
02/13/25 11:24 AM
Posts: 2,842 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I've done that before. They have to change the lobe profile itself but they can give you the same specs.
2011 Drag Pak Challenger
[Re: A/MP]
#3289520
02/14/25 08:45 PM
02/14/25 08:45 PM
Posts: 6,197 Melbourne , Australia
LA360
I very much doubt you'll find a solid roller camshaft that will have the same seat timing and lobe lift. I'd expect the solid roller to have more lobe lift.
Alan Jones
[Re: A/MP]
#3289526
02/14/25 09:05 PM
02/14/25 09:05 PM
Posts: 4,354 Prospect, PA
BSB67
Prospect, PA
I'm looking to see if the roller , because of its faster ramp, needs a different spec? I guess I'm looking to find out if the roller will make more power with a similar cam profile. What specs are you referring too? Adv duration, 0.050 duration, 0.200 duration and max lift? If all those Specs are the same between the two cams, the lobes will not be faster, and the power will be the same.
