Hi,
I have a 2009 Dodge Ram 1500. Early in December, the dash lights and radio stayed on after removing the key, I put it back in, wiggled the shifter, pulled it out and the problem was solved, so I thought.
About 10 days later, the problem happened again, but my remedy did not work. I was advised to replace the fob batteries, but tried my other factory fob, and again the problem was solved, so I thought. I went to move the truck to clear some snow and the problem came back. I disconnected the battery until I could replace the batteries in both fobs.
After replacing the batteries, the problem is still there. This time though, 1 of the fobs will lock and unlock the doors and the other won't.
I have looked this up and discovered that it could be the actual ignition switch where the fob goes in. While it's an easy replacement, it will require me to go to the dealer to get the fob paired.
Looking for any other solutions out there before having to go to the dealer.
If I replace the ignition switch, can I get the fob paired somewhere else (less expensive)?
Thanks,
