Re: Magnum engine interchange question
[Re: volaredon]
#3273515
12/02/24 05:32 AM
12/02/24 05:32 AM
Posts: 41 Stafford, VA
ojcool
Stafford, VA
I know a magnum will directly bolt in place of an LA engine. And I have seen it done with either LA or magnum timing covers water pump and belt drive. The question has to do with keeping working ac on a truck that already has it, If using the LA front cover and multiple belts and a carburetor intake manifold, what ac pump and which bracketry is used? All LA stuff? All magnum stuff! Some conglomeration between them? AC pump in question is the round aluminum in both cases. Not the old RV2 I did a magnum swap in a 1991 Dakota and I just bolted all the accessories from the LA on. In my case the LA had a serpentine setup but it did have one less rib on the pullies on the LA. The LA had an air pump so finding a belt the right length is a problem.
[Re: Andrewh]
#3273524
12/02/24 06:53 AM
12/02/24 06:53 AM
Posts: 1,195 rust belt
Moparite
rust belt
The question has to do with keeping working ac on a truck that already has it So i assume you want to use a magnum in place of the LA. What year truck/LA? Are you running a R12 or 134A compressor? Also what intake are you using and does it have provisions for the brackets? May take a look here for swap info.
[Re: volaredon]
#3274033
12/04/24 11:07 AM
12/04/24 11:07 AM
Posts: 3,309 West Coast, USA
jbc426
West Coast, USA
Truck is 83. Will become a 134 system. Yeah I'm using a magnum long block. Carbureted intake, not sure yet which. That's gonna depend on what manifold I can find or else a drill fixture to drill my heads-or not. It won't be the beer barrel as used stock on the magnums originally Be sure to use a triple pass condenser and a fresh receiver/dryer with the R-134.
